Ubuntu Budgie. Slow and glitchy
Yip only HDD.
I am actually trying out your suggesion for OnlyOffice right now. So far the the RAM usage has been stable, but I miss the Libreoffice workflow. Will be using OnlyOffice for at least another month just to see if I get strange spikes in RAM usage. My only gripe with OO now is that I can’t find documentation that allow me to create templates similar to those I did on LO.
Thanks for the PPA - After my OO experiment I’ll use this, so I can get a comparison.
As for Swapiness. You are the second person suggesting it to me. I’ll read up on it and thank you for the link.
Thank you mate. I’m learning quite a bit.
So, avoid installing programs in snap package for the moment. They might be slow on only-HDD setups.
These helps are more aimed at online version of OnlyOffice but should give some hints for the general usage.
Hence entries regarding « collaborative work » won’t apply.
What happens when you open templates made with LO in OO ?
Maybe from LO convert those templates into a regular file ?
I’m not an OO user myself so it was just a « workaround » suggestion.
If the RAM problem can’t ever be solved, you’d probably need to try a « lighter » Ubuntu flavor, like Mate Ubuntu or Xubuntu.
Just popped in to thank you guys for all the help. Libreoffice 7 solved all my issues I had.
I really appreciate the guidance and patience.
