Hello
I have noticed on every new kernel download that I have to add the vpn application to auto start every time. Bit of a pain. Can this be fixed?
Hello
Well thats something the VPN app provider should be able to help you with.
If they are using kernel modules then hopefully they have made their software “dkms” compliant - i.e. install the dkms package. Compliant apps recompile themselves when a new kernel lands.
Okay. Thank you for that.
