almost each time I launch Thunderbird - be it in full or non-maximized window - it makes pixel saver applet crash for a moment. I just have to maximize or un-maximize window for pixel saver applet to come back.
It’s 18.04 here, and TB 68 but it used to do the same with previous TB.
coeur-noir@asgard:~$ thunderbird -v
Thunderbird 68.2.2
1578246001757 addons.xpi WARN Can't get modified time of /usr/lib/thunderbird/features/wetransfer@extensions.thunderbird.net
console.log: WebExtensions: Loading packed extension from /home/coeurnoir/.thunderbird/jwxzhqor.default/extensions/gContactSync@pirules.net.xpi
console.log: WebExtensions: Loading packed extension from /home/coeurnoir/.thunderbird/jwxzhqor.default/extensions/{a62ef8ec-5fdc-40c2-873c-223b8a6925cc}.xpi
console.log: WebExtensions: Loading packed extension from /home/coeurnoir/.thunderbird/jwxzhqor.default/extensions/{e2fda1a4-762b-4020-b5ad-a41df1933103}.xpi
console.log: WebExtensions: Loading add-on preferences from /home/coeurnoir/.thunderbird/jwxzhqor.default/extensions/gContactSync@pirules.net.xpi
console.log: WebExtensions: Firing profile-after-change listeners for gContactSync@pirules.net
console.warn: Overlays.jsm: Could not resolve 3 references Array [{},{},{}]
console.log: WebExtensions: Loading add-on preferences from /home/coeurnoir/.thunderbird/jwxzhqor.default/extensions/{a62ef8ec-5fdc-40c2-873c-223b8a6925cc}.xpi
console.log: WebExtensions: Firing profile-after-change listeners for {a62ef8ec-5fdc-40c2-873c-223b8a6925cc}
console.log: WebExtensions: Loading add-on preferences from /home/coeurnoir/.thunderbird/jwxzhqor.default/extensions/{e2fda1a4-762b-4020-b5ad-a41df1933103}.xpi
console.log: WebExtensions: Firing profile-after-change listeners for {e2fda1a4-762b-4020-b5ad-a41df1933103}
[calBackendLoader] Using Thunderbird's builtin libical backend
console.warn: Overlays.jsm: Could not resolve 1 references Array [{}]
console.error: Lightning:
[calCachedCalendar] replay action failed: null, uri=googleapi://me@gmail.com/?calendar=%23contacts%40group.v.calendar.google.com, result=[object Object], operation=[xpconnect wrapped calIOperation]
1578246031888 addons.xpi WARN Failed to parse recommendation: TypeError: NetworkError when attempting to fetch resource. No traceback available
console.log: WebExtensions: Legacy WebExtension {e2fda1a4-762b-4020-b5ad-a41df1933103} has already been loaded in this run, refusing to do so again. Please restart.
