I have two 4k screens with different scaling.
300% for notebook and 200% for external screen.
I’m using only one screen at the time.
I noticed that budgie-wm generate constant cpu load once scaling was changed.
I have tested this issue even without external screen. Just change scaling and you will have budgie-wm at the top of htop at the idle.
Yes, you are right. Nvidia optimus with performance mode. So Nvidia enabled.
I have no choice cos on Thinkpad P50 Nvidia should be active if you want to use external screen =(
I think I may have seen past reports on this - this probably a mutter issue at a guess - mutter is the window manager - on budgie you see mutter as a “budgie-wm” process.
Please file a bug report on launchpad to report this.
I presume on a reboot the scale settings is retained but the idle reduces ? or is it permanently at 10% due to the scale settings - but low if scale = 100%?
Yes, I read about high cpu load on nvidia. And I can confirm, that. Tested on intel gpu and it eat much less cpu.
But this exact bug looks new for me. There is no such issue if scaling was not changed.
I’ll be honest … without similar hardware its not something that either the Solus team or ourselves will delve into. It will need someone to dig in (somehow) to find out what is going on.
For what it’s worth, on 4k/scaling 200% + frequent changes: Nvidia driver is make fan spin at high speed constanly, on nouveau, didn’ t hear my fan yet and consumption is much, much lower.
I’m guessing you can install the debug budgie-desktop packages.
Then run GTK_DEBUG=all budgie-wm --replace &
This will start throwing out debug messages.
Then change the scaling.
Look at the debug messages - hopefully you should start seeing a massive increase - and hopefully the messages will say where in the code the issue is.
As mentioned previously - I don’t believe this is actually a budgie-desktop issue - its a corner case mutter issue that gnome-shell does not impact.
So installing the debug packages for mutter probably should be done as well
