20.04 freshly installed here. Pictures better than words ?
and
Anything I can tinker ?
( or what is it meant by desktop style : the pocillo default one, with blue highlights ? )
So my question actually maybe is :
how can I set « more » transparency on panels to Vimix-dark-ruby theme ?
.budgie-panel {
transition: background-color 100ms cubic-bezier(0, 0, 0.2, 1);
background-color: #222222;
color: rgba(255, 255, 255, 0.7);
font-weight: 500;
.budgie-panel.transparent {
background-color: rgba(34, 34, 34, 0.85);
Done !
.budgie-panel {
color: rgba(255, 255, 255, 0.9);
font-weight: 500;
background-color: rgba(34, 34, 34, 0.1);
…by creating
$HOME/.local/share/themes/vimix-dark-ruby/gtk-3.0
copying there the .css file from
/usr/share/themes/vimix-dark-ruby/gtk-3.0/gtk.css
and modifying « locally » for this user as shown above.
Problem now : this has an effect on other parts of the interface ! Not only the panels.
Radio buttons are now also transparent…
In sass the pixelsaver has its own specific styling that can be translated to css
// used to indicate unread notifications
.alert {
color: theme-color.primary(theme-color.$on-panel);//theme-color.error(theme-color.$on-panel); Materia
// End Section needs to be fancy
.end-region {
// background-color: rgba(0,0,0,0.2);
// budgie-pixel-saver-applet
.titlebar:not(headerbar) {
min-height: 0;
padding: 0;
box-shadow: none;
background-color: transparent;
color: theme-color.$on-panel;
button:not(.suggested-action):not(.destructive-action) {
color: theme-color.hint(theme-color.$on-panel);
Naa… ok I’ve found why.
Buttons were not transparent , they were missing .
Needed assets in the same directory as gtk.css file.
So I did a symlink
cd ~/.local/share/themes/vimix-dark-ruby/gtk-3.0/
ln -s /usr/share/themes/vimix-dark-ruby/gtk-3.0/assets
and everything’s fine now <3
Hope I’ll be able to do the same in 22.04…
