26.04 is totally broken
  1. wayland update - absolute disaster. What profit btw?
  2. plank removed (no wayland support) crystal dock raw as ****.
  3. keyboard shortcust become trash.
    1. No Cmd + shift + right for switching displays.
    2. No Esc for creating applets???
    3. Alt + Space quick run?
    4. App menu - typing app name clicking button down and cursor still in text box… Click right change focus?? Why not tab like in windows xp(sarcasm)
I predict what moderator will arive and said what all works and he cant reproduce. I believe it works on fresh install, but what about updating? First time i will need to downgrade sadly
Hi @dontepanlin!
Well, I’m not a moderator, but I’d like to point out that you’ve already answered all your own questions: why did you upgrade to 26.04 without even trying it out first — especially with the switch to Wayland and 7.0?
As for me, I’m still using 24.04.4 and trying out 26.04.
And nothing beats a fresh install — it gets rid of all the junk lurking in the background. :smiley:
  1. you need to configure your rc.xml for those key combinations - under wayland you need to control yourself what “displays” mean - each display has its own name
  2. I have no idea what “esc for creating applets” means - there is no such key in 24.04
  3. Alt + Space quick run - what does this mean? is this for changing your keyboard source? Thats Alt + Shift by default
  4. App menu - if you don’t like the default menu then use the inbuilt menu in budgie-desktop-settings.
If you don’t like the dock then switch to another layout that suits your workflow.
On this forum we all conform to the ubuntu code of conduct. Be respectful to those to who may wish to help you
Alt + F2
I don’t mean to offend you, but I kind of get the feeling you’re still on a Mac.
