Automatic connection of the Flugir-Budgie theme
The “Flugir-Budgie” Snap theme has finally gained auto-connection, so anyone who wants to use the theme will no longer need to use commands to use it in Snap applications.
I also added files for using it in Ubuntu 25.04
If you want to install the theme and the Snap version, you can use this command:
wget https://github.com/Kyuyrii/Flugir-Budgie/releases/download/Flugir-Budgie-0.9.4/WFB-0.9.4.tar.xz && tar -xf WFB-0.9.4.tar.xz && ./FBF-0.9.4/IFB.sh && sudo snap install flugir-budgie-theme
