Hi all
Our Beta 2 ISOs have now been released for this CRITICAL milestone.
Please help to test this milestone - everyone should be able to do something to test this for us all.
http://iso.qa.ubuntu.com/qatracker/milestones/388/builds
Download links and tests are in the link above - but a direct download is here also:
http://cdimage.ubuntu.com/ubuntu-budgie/daily-live/current/
Honestly it is simple as 1,2,3
- Download the ISO and select the test case from the QA tracker above
- Test install the ISO according to the test case
- IMPORTANT - Record the results - whether it passes or fails
Below is basically what our friends from the xubuntu community has received - it does apply to Ubuntu Budgie as well - it may seem long but please - please - please read-on.
The ISO Tracker has seen little activity for the last few development cycles. We know we have some excited users already using and testing 18.04. But without testing results being recorded anywhere, we have to assume that nobody is testing the daily images and milestones. And this has major implications for both the 18.04 release and the project as a whole.
From the perspective of the QA team, and with full support from the development team – If we aren’t able to gauge an ISO at any of the milestones (Beta, Final Beta, Release Candidate, and the LTS Point Release), how can we possibly mark those as “Ready for Release”? And why should we?
It is notable that following any of our releases, often within less than a day, we have multiple reports of issues that were NEVER seen on the ISO Tracker. With the current SRU procedure, this means that all users will now have a minimum of 7 days before they can possibly see a fix. With development and testing time, these fixes may take significantly longer or never even make it into the 3-year support release.
Ubuntu Budgie is a community project. That includes all of you. If the community doesn’t care until it’s too late, what should we take from that? In fact, community support is part of the deal every flavor makes with Canonical to enable all of the things that make it possible for the flavor to exist. It’s actually the first bullet point in remaining a recognized flavor:
- Image has track record of community interested in creating, supporting and promoting its use.
Ready to help? Let’s do this.
It is now time for the community to step up. Test ISOs, test the versions of packages you regularly use, check for any regressions, and record your results!
For those of you who do not believe you can help… you can!
Regression Testing
How hard is it to check for regression? Use the software you use every day. Does it work differently than it used to?
If not, no regression!
If it does, but works better than before, no regression!
Anything else, you’ve found a regression. Report it !
ISO Testing
How hard is it to check an ISO? If you have at 10Gb of disk space available, read on.
If you have sufficient disk space for a 10Gb file, you can probably use a virtual machine to run installation and post-installation tests. We prefer real hardware - but a VM is better than not testing!
If you are able to virtualize but lack the disk space for a full installation, consider using a VM to verify the ISO boots and applications run on the live disk.
If you have physical media available, either a DVD-R (RW to not waste the media on daily tests) or 2+ Gb capacity USB stick, you can boot Ubuntu Budgie from the media and perform installation, post-installation, and live testing.
We hope that you’ll join us in making Ubuntu Budgie 18.04 a success. We think it’s going to be the best release ever, but if the community can’t find the time to contribute to the release, we can’t guarantee we can have one.
thanks all
David (Project Lead)
Is there a password I was unaware of?
It loaded in fine from the Etcher installer, I surfed the web briefly with Chromium, typed a quick note from the top bar clipboard, opened a rather large Calc file and looked under the hood with (?) Terminal - I think it was called Tilix?
