I have nemo on 19.04. bookmarks not working. No option for their use. I installed Nautilus, same problem. Has that feature been elimnated? Too bad, if so.
I’m running UB 19.04 with nemo 4.0.6 and bookmarks work just fine. There’s a bookmark item in the nemo menu bar and also in the context menu for network directories. I’ve got two DAV directories bookmarked no probs at all.
Unfortunately what you mentioned, the bookmarkitem, is exactly what I am missing.
