Hi! Don’t know if this is the right place to ask, but I use a Macbook Pro 12,1 (BCM43602 WIFI/BT Chipset) but whenever I connect to my Bluetooth headset (Bose Soundlink 2) the audio becomes all jittery after a few seconds
Huh. Turns out the issue was fixed by running the following command
service bluetooth restart && killall pulseaudio
That restarts bluetooth, and then kills pulseaudio, the audio daemon, so it makes no sense that that command works, but I don’t play around with that stuff, so I’m not sure
