Budgie Desktop not launching (login loop)
I’ve been using Ubuntu Budgie 19.04 without issues for the past months, and I just upgraded to 19.10 with:
sudo do-release-upgrade -d
After reboot I could no longer login to the desktop with Budgie selected. After entering password, the screen goes blank with a cursor on it for a few seconds, then completely black and shortly after, back to the login screen.
The standard Ubuntu/gnome desktop, as well as Ubuntu on Wayland work normally.
The laptop is on Intel graphics, no other video cards/drivers exist.
sudo lspci -k | grep -EA3 ‘VGA|3D|Display’
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09)
Subsystem: Lenovo Haswell-ULT Integrated Graphics Controller
Kernel driver in use: i915
Kernel modules: i915
Permission of .Xauthority and /tmp seems file (.ICEauthority doesn’t exist for some reason):
foxium@lenovo:~$ ls -lA .Xauthority
-rw------- 1 foxium foxium 57 Oct 9 14:26 .Xauthority
foxium@lenovo:~$ ls -ld /tmp
drwxrwxrwt 22 root root 12288 Oct 9 14:31 /tmp
I tried uninstalling “everything” to start from scratch:
sudo apt purge ubuntu-budgie-desktop budgie*
Restarted to make sure Budgie is gone, then from console:
Restarted again after making sure lightdm is selected as the default display manager, however the login loop persists.
journalctl log entries: https://pastebin.com/CsrFfk4h
Any ideas on how to fix this? Thanks for your help!
I need a clean paste.ubuntu.com trace for your journalctl log entries because you have too much login/logout stuff from the other sessions.
Please reboot. Switch to a TTY (CTRL+ALT+F3) and login. Switch back to the slick login manager (CTRL+ALT+F3) and attempt to login.
Switch back to the TTY and write out the journalctl log
journalctl -ae --full > output.txt
This will create journal entries in output.txt
Thanks @fossfreedom for the quick response.
I rebooted, logged into tty3, went back to GUI login with Budgie selected. After the said problem occurred again and screen returned back to login, I went to tty3 and collected the following log:
https://paste.ubuntu.com/p/x4jmwfWzzS/
Hope this helps determining the problem.
Thanks again! Really appreciate your help.
you have a number of issues that appear to be coming from the GNOME Stack
lenovo gsd-smartcard[22753]: specified class size for type 'GsdSmartcardService' is smaller than the parent type's 'GsdSmartcardServiceManagerSkeleton' class size
Oct 09 16:37:06 lenovo dbus-daemon[1273]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.385' (uid=1000 pid=22732 comm="/usr/lib/gnome-settings-daemon/gsd-rfkill " label="unconfined")
Oct 09 16:37:06 lenovo gsd-smartcard[22753]: g_type_add_interface_static: assertion 'G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
Oct 09 16:37:06 lenovo gsd-smartcard[22753]: g_once_init_leave: assertion 'result != 0' failed
Oct 09 16:37:06 lenovo gsd-smartcard[22753]: g_async_initable_new_valist_async: assertion 'G_TYPE_IS_ASYNC_INITABLE (object_type)' failed
That tells me that the package gnome-settings-daemon needs a rebuild - this will happen automatically in the next few days when the GNOME Stack 3.34.1 packages are released.
Oct 09 16:37:06 lenovo gsd-xsettings[22720]: Failed to get current display configuration state: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.gnome.Mutter.DisplayConfig" does not exist
That’s a mutter issue where it cannot read your display info - what are you connected to? a laptop screen or an external display?
Oct 09 16:37:06 lenovo gsd-media-keys[22733]: Failed to grab accelerators: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.gnome.Shell” on object at path /org/gnome/Shell
Oct 09 16:37:06 lenovo budgie-wm[22789]: Failed to start Xwayland: Failed to acquire window manager ownership
Oct 09 16:37:06 lenovo kernel: show_signal: 54 callbacks suppressed
Oct 09 16:37:06 lenovo kernel: traps: budgie-wm[22789] trap int3 ip:7fda85bc48f5 sp:7ffd6a023440 error:0 in libglib-2.0.so.0.6200.0[7fda85b89000+83000]
Oct 09 16:37:07 lenovo budgie-wm.desktop[22789]: Window manager warning: Display “:0” already has a window manager; try using the --replace option to replace the current window manager.
Oct 09 16:37:07 lenovo gnome-session[22676]: gnome-session-binary[22676]: WARNING: Application 'budgie-wm.desktop' killed by signal 5
Oct 09 16:37:07 lenovo gnome-session-binary[22676]: WARNING: Application 'budgie-wm.desktop' killed by signal 5
Oct 09 16:37:07 lenovo dbus-daemon[1273]: [system] Successfully activated service 'org.freedesktop.locale1'
Oct 09 16:37:07 lenovo systemd[1]: Started Locale Service.
Oct 09 16:37:07 lenovo dbus-daemon[4687]: [session uid=1000 pid=4687] Activating service name='ca.desrt.dconf' requested by ':1.54' (uid=1000 pid=22829 comm="budgie-panel " label="unconfined")
Oct 09 16:37:07 lenovo dbus-daemon[4687]: [session uid=1000 pid=4687] Successfully activated service 'ca.desrt.dconf'
Oct 09 16:37:07 lenovo budgie-wm[22840]: Failed to start Xwayland: Failed to acquire window manager ownership
Oct 09 16:37:07 lenovo kernel: traps: budgie-wm[22840] trap int3 ip:7f96d56be8f5 sp:7ffdf9ff70b0 error:0 in libglib-2.0.so.0.6200.0[7f96d5683000+83000]
Oct 09 16:37:07 lenovo budgie-wm.desktop[22840]: Window manager warning: Display “:0” already has a window manager; try using the --replace option to replace the current window manager.
Oct 09 16:37:07 lenovo gnome-session[22676]: gnome-session-binary[22676]: WARNING: App 'budgie-wm.desktop' respawning too quickly
Oct 09 16:37:07 lenovo gnome-session-binary[22676]: WARNING: App 'budgie-wm.desktop' respawning too quickly
Oct 09 16:37:07 lenovo gnome-session-binary[22676]: Unrecoverable failure in required component budgie-wm.desktop
Oct 09 16:37:07 lenovo gnome-session[22676]: gnome-session-binary[22676]: CRITICAL: We failed, but the fail whale is dead. Sorry....
Oct 09 16:37:07 lenovo gnome-session-binary[22676]: CRITICAL: We failed, but the fail whale is dead. Sorry....
Oct 09 16:37:07 lenovo pulseaudio[4684]: ICE default IO error handler doing an exit(), pid = 4684, errno = 88
Then that above is the budgie window manager crash
Why the issue about XWayland I don’t know - mutter shouldn’t be trying to start XWayland but I strongly suspect its due to the "Failed to get current display configuration state: " message
Thanks again for the amazingly fast reply.
The laptop is connected to an external screen via it’s onboard HDMI port.
Apart from waiting for the gnome-settings-daemon, is there anything I can try at this point?
Thanks again.
I’ve got the same problem.
Occurred after upgrading gnome-session today, before it worked fine.
Cheers
If you disconnect your external screen can you login just using your laptop display?
Disconnecting the external screen made no difference – same problem persists along with the same display configuration error:
Oct 09 18:34:40 lenovo gsd-xsettings[8902]: Failed to get current display configuration state: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name “org.gnome.Mutter.DisplayConfig” does not exist
Whilst not really helpful - you are not alone with the observation - also occurs on earlier versions of Ubuntu as well
Can you boot into a live-session? Just wondering if there is something with your installation that is clashing - a live session is a clean environment.
Okay I will give it a try and report back.
ok - think I understand the issue now - its due to you have both gnome-shell and budgie-desktop installed.
I’ve thrown a bug-fix and hopefully it will be accepted soon. Will keep you informed.
I’ve tried 19.10 live and it works fine, but it probably doesn’t matter now as you have already found the problem. I’ll remove gnome-shell when I have time to tinker, or just wait for the fix you pushed.
Really appreciate your help. Thanks again! This community is simply amazing.
Bug fix has now been released - it will take a while for the mirrors to pick up - but just update as normal and you should see the update come down the wires.
Working fine now after updating. Thank you fossfreedom.
