I notice that sometimes the panel crashes for a second, then reopens back up. Is there a way to fix this?
Also seems to happen with a reset. I just did another reset and am not going to customize, see how it goes. Only things I changed from the default panel were these, btw:
- added night light
- moved the icon task list to center
- changed menu icon
- removed a spacer
I had the same, but only with Network or system tray in it. Both show the WiFi icon.
I don’t have system tray. Anyways after the reset it’s fine, will make changes incrementally to see what caused it.
