I updated just now and on reboot I have NO top panel. In terminal I typed budgie-desktop-setting amd got the gui. Under top panel it only has visual space, applicator applet, status indicator, seperator.
How to get the original back
thanks pete
Sounds like you had a crash or you forced a shutdown? Either way the panel has become corrupted.
To reset back to the defaults use ctrl+alt+t to open a terminal
Then type
Hi fossfreedom, you are correct, it had a freeze and I hit the power
Thanks I used your fix
pete
Edit: This problem had nothing to do with the update.
