BUG My Budgie panel has issues 3-18-19
Help.
I’m using Ubuntu Budgie 18.04 Since last update, my budgie panel has stopped working correctly. The system tray isn’t visible, in spite of being activated in the panel. The power button is also not visible. Some of my widgets (like Calendar) disappeared from the panel and I had to activate them again.
The Previews Applet is not showing my windows either.
Help, please?
Reset your panel via Ctrl+alt+t to open a terminal then
Thanks, that did the job!!!
