Budgie Welcome incorrectly scaling view
I’m a relative newbie to the world of Ubuntu-Budgie and any help is greatly appreciated!
I have an issue that whenever I open Budgie Welcome and related ‘Makeovers and Layouts’ etc. my view is sorta zoomed into the bottom left corner. I can’t click on any of the buttons that I can see either. I have reformatted my drive and reinstalled the OS, even re-downloading the ISO, and the issue persists. The issue occurs only after the first batch of updates, post-installation. I have noticed this message in the logs: 18:53:18 xdg-desktop-por: Realtime error: Could not map pid: Mapping pids is not supported. which occurs after launching Budgie Welcome :face_with_spiral_eyes:
Logs
18:53:23 kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC=01:00:5e:00:00:fb:2a:b2:fc:1b:d2:50:08:00 SRC=192.168.1.226 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=46216 PROTO=2
18:53:17 systemd: Started snap.ubuntu-budgie-welcome.budgie-welcome-0afa1451-6f34-4426-88b3-bd59001a5724.scope.
18:52:58 budgie-wm: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x3a00004
18:52:58 windowshufflerd: AT-SPI: Error in GetItems, sender=:1.31, error=Object does not exist at path “/org/a11y/atspi/cache”
18:52:57 dbus-daemon: [session uid=1000 pid=2378] Successfully activated service 'org.gnome.Logs'
18:52:57 budgie-panel: file ../../../gio/gfileinfo.c: line 1655 (g_file_info_get_is_backup): should not be reached
18:52:51 sudo: pam_unix(sudo:session): session closed for user root
18:52:36 systemd: Finished esm-cache.service - Update the local ESM caches.
18:52:36 sudo: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
18:52:22 systemd: Started vte-spawn-d0de9c52-ea08-4593-b547-619468ded5b2.scope - VTE child process 4183 launched by tilix process 4172.
18:52:22 tilix: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
18:52:22 dbus-daemon: [session uid=1000 pid=2378] Successfully activated service 'com.gexperts.Tilix'
18:52:18 aptd: 18:52:18 AptDaemon.Worker [INFO]: Finished transaction /org/debian/apt/transaction/092e0a5550fc490ca6106aabad8cf479
18:52:17 systemd: Started packagekit.service - PackageKit Daemon.
18:52:17 dbus-daemon: [system] Successfully activated service 'org.freedesktop.PackageKit'
18:52:17 packagekitd: daemon start
18:52:17 systemd: Starting packagekit.service - PackageKit Daemon...
18:52:17 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.93' (uid=0 pid=4079 comm="/usr/bin/gdbus call --system --dest org.freedeskto" label="unconfined")
18:52:17 systemd: Finished esm-cache.service - Update the local ESM caches.
18:52:16 aptd: INFO: Updating cache
18:52:16 dbus-daemon: [system] Successfully activated service 'org.debian.apt'
18:52:16 aptd: 18:52:16 AptDaemon [INFO]: Initializing daemon
18:52:16 dbus-daemon: [system] Activating service name='org.debian.apt' requested by ':1.90' (uid=1000 pid=3574 comm="/usr/bin/python3 /usr/bin/update-manager" label="unconfined") (using servicehelper)
18:52:16 update-manager: WARNING:root:can not import unity GI Namespace Dbusmenu not available
18:52:15 budgie-panel: file ../../../gio/gfileinfo.c: line 1655 (g_file_info_get_is_backup): should not be reached
18:52:07 kernel: [UFW BLOCK] IN=wlp0s20f3 OUT= MAC=01:00:5e:00:00:fb:1c:53:f9:a5:4c:4f:08:00 SRC=192.168.1.85 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=65131 PROTO=2
18:52:03 systemd: systemd-hostnamed.service: Deactivated successfully.
18:52:01 snapd-desktop-i: atk-bridge: get_device_events_reply: unknown signature
18:51:55 budgie-panel: PowerIndicator.vala:66: Failed to refresh battery: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Method Refresh is not implemented on interface org.freedesktop.UPower.Device
18:51:50 NetworkManager: <info>  [1706467910.0739] dhcp6 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
18:51:45 budgie-panel: sys:1: Warning: g_bytes_compare: assertion 'bytes1 != NULL' failed
18:51:42 budgie-wm: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x3800004
18:51:42 windowshufflerd: AT-SPI: Error in GetItems, sender=:1.25, error=Object does not exist at path “/org/a11y/atspi/cache”
18:51:42 systemd: user-113.slice: Consumed 1.142s CPU time.
18:51:42 wireplumber: disconnected from pipewire
18:51:42 systemd: Stopping wireplumber.service - Multimedia Service Session Manager...
18:51:42 gvfsd: A connection to the bus can't be made
18:51:42 systemd: Stopping dconf.service - User preferences database...
18:51:42 dbus-daemon: [session uid=1000 pid=2378] Successfully activated service 'org.gnome.Logs'
18:51:41 budgie-panel: file ../../../gio/gfileinfo.c: line 1655 (g_file_info_get_is_backup): should not be reached
18:51:36 wpa_supplicant: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-42 noise=9999 txrate=1200900
18:51:36 snapd-desktop-i: All available theme snaps installed
18:51:36 systemd: Started xdg-desktop-portal.service - Portal service.
18:51:36 dbus-daemon: [session uid=1000 pid=2378] Successfully activated service 'org.freedesktop.portal.Desktop'
18:51:36 rtkit-daemon: Supervising 14 threads of 8 processes of 2 users.
18:51:36 systemd: Started xdg-desktop-portal-gtk.service - Portal service (GTK/GNOME implementation).
18:51:36 dbus-daemon: [session uid=1000 pid=2378] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
18:51:36 systemd: Starting xdg-desktop-portal-gtk.service - Portal service (GTK/GNOME implementation)...
18:51:36 dbus-daemon: [session uid=1000 pid=2378] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.gtk' unit='xdg-desktop-portal-gtk.service' requested by ':1.81' (uid=1000 pid=3351 comm="/usr/libexec/xdg-desktop-portal" label="unconfined")
18:51:36 systemd: Starting xdg-desktop-portal.service - Portal service...
System Specs
Hardware Model: Lenovo Yoga Pro 7 14IRH8
Memory: 16.0 GiB
Processor: 13th Gen Intel® Core™ i7-13700H × 20
Graphics: Intel® Graphics (RPL-P)
Budgie Version: 10.8
OS Name: Ubuntu 23.10
OS Type: 64-bit
Windowing System: X11
Kernel Version: Linux 6.5.0-15-generic
duplicate of Scaling and 4k monitor issues - #3 by driver8
