Login Screen: High Resolution screens, make the login font … unbelievable small! Fix it!
Top Panel: Adding & Removing applets results in applets disappearing completely. Everything from Bluetooth, sound and Power button disappears … (!) Adding plugins does not show missing plugins again
Doesn’t start after install:
- Flameshot
- Power Off or Reboot. (I have to do it in Terminal)
- Discover unable to install Flatpak (Yes Flatpak & Repo OK!)
- wdisplays: does not remember it last windowsize
- Auto arrange icons on desktop: impossible to deactivate
- Right Click on Desktop: Only 3 option shows: Budgie Desktop Settings, System settings and AutoArrange. (Nothing else) What happened to: New Folder, file and so on?
- Budgie Control Center: Where is Display, Bluetooth,
- “Show Time Widget” in desktop - suddenly misses Month - "April is gone, just “25” left
- File transfer - How slow can you make it?
- Floating/Glass Task Manager … useless: What was wrong with the old one in 25.10?
- Install apps takes forever
- Autostart does NOT start apps
- … and so on, and so on … (!)
