Bugs won't Sleep
Just upgraded from LTS 18.04 to 20.04 and now system won’t blank screen and sleep? Anyone else seeing this. Sorry for the ask, location where I should report.
Thanks in advance.
Very Respectfully,
Gary
These sorts of issues can either be graphical issues or kernel issues or a combination of both.
So do check if you have the latest graphics and possibly linux firmware installed via Menu - Hardware drivers
If no luck via that route then please file a bug against the kernel https://wiki.ubuntu.com/Kernel/Bugs
Btw Dear, I Suggest You To Make Clean Installation… I Dont Like Upgrade :crazy_face:
Try to check if sleep and screen blanking aren’t turned off in Gnome Settings.
Thanks, yes checked both.
Very Respectfully,
Gary
Thanks, yes thinking same. I also have issues with scanner recognition.
Very Respectfully,
Gary
Did a fresh install of 20.04LTS Budgie and problem disappeared.
Thanks for the help.
Very Respectfully,
Gary
