Calendar Applet: custom date not preserved
I’m using Budgie Calendar Applet. I noticed that custom date format isn’t preserved between logins.
Any solutions?
I found that to make the format to save you need to hit ENTER on the format edit field. It doesnt save if you just make the change without hitting ENTER.
Great. It works, thanks.
