Camera not seen on cheese - got the errors from terminal
Hello,
I am running ubuntu budgie in a macbook air 2018.
Cheese says “there was an error playing video from the webcam” and guvcview can see the camera
Under Settings the camera is not shown
If I check “additional drivers” I see the following:
“Broadcom Inc and subsidiaries : 720p FaceTime HD Camera
This device is not working
Option 1; using Kernel driver for FacetimeHD amera from facetimehd-dkms (open source)
Option 2: continue using a manually installed driver
Option 3: do not use the device”
I cannot choose another option than 3
The terminal shows these errors:
MacBookAir7-2:~$ guvcview -d /dev/video0
V4L2_CORE: Unable to find parent usb device.GUVCVIEW: version 2.0.8
V4L2_CORE: (UVCIOC_CTRL_MAP) Error: Inappropriate ioctl for device
ALSA lib pcm_dsnoop.c:567:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:1000:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2721:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2721:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2721:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
control[0]:(unknown - 0x6) 0x980001 ‘User Controls’
I would be very thankful for a hint what to do next
Thanks
Lucia
Avoid using cheese. It wasnt working during the 24.04 development cycle and hence why we dropped it on favour of guvcview.
I havent checked since whether later versions of ubuntu have a fixed version of cheese.
