How to Fix Camera
I am new to Linux and Ubuntu. I installed Budgie and cannot find a way to turn on my laptop camera. Do I have to download an app for that? If so, any recommendations? I have seen people recommend Cheese or Shotwell. Thanks.
Hi @Guimar!
I don’t use it, but Cheese seems to be just the thing.
To install it, launch the terminal (Ctrl Alt t) and enter these lines one after the other:
sudo apt update
sudo apt install cheese
…and come back to tell us.
Hi @jib,
Will do! Thanks.
It worked. Thank you!
