Failed to start session
(from #ubuntu-budgie irc, it’s quiet there)
After installing Wine from Software Centre, I got an error for unmet depencies, after reboot I can’t get to the desktop enviroment ‘Failed to start session’ , first thing google gave me was to ‘sudo apt-get install ubuntu-desktop’ from ctrl-alt-f1, Now I can login to Ubuntu and Ubuntu on Wayland, but not Budgie. Want my Budgie back :frowning: Running Ubuntu Budgie 18.10.
Sounds like something has accidentally been uninstalled
Try
sudo apt install --reinstall ubuntu-budgie-desktop budgie-desktop budgie-core gnome-control-center
also worth trying
This is to confirm everything is fully up to date
:sob: Got to budgie, but things are off and some things corrupted…
The new mutter that has been uploaded to 18.10 has cause a bunch of issues - tracking stuff here.
If you have anything extra please add to the upstream issue tracker. Thanks.
Thank you for the solution.
