I upgraded from 23.04 to 23.10 and now sometimes the computer fails to start. After several reboots the computer starts normally. How can I solve this problem?
Hello,
Just wanted to chime in that my solution solved my issue and I have not seen this screen again since. Since you mentioned having to reboot several times it sounds very similar to my issue
If you do try my original solution and it doesn’t do the trick then this link will help:
Good luck!
