Can anyone tell please tell me if there is a way to universally zoom all folders with one setting? I seem to have to zoom a folder such as “Files” but then when I create a new folder inside, it is at the original size and I have to zoom that too and so on.
Thank you very much! It was the “Ignore per-folder view preferences” that did it.
CORRECTION: I’M WRONG AND THE PROBLEM PERSISTS.
I’m using UB19.04, Nemo 3.8.5.
In File settings I have set:
Icon view defaults to 150%
and
Behaviour “Ignore per-folder preferences” ticked.
In fact, having just gone in and out of the settings, it would appear that this problem is erratic, because all my folders are now at 150%. This was not the case prior to going into my settings 5 minutes ago.
It does seem a lot better but changing the zoom doesn’t appear to be immediate. Closing Files (now Nemo 4.0.6) and opening it again produces a persistent result across logging out and back in.
Thx for you help.
PS I think the idea of accessing “Budgie Discourse” through the menu is brilliant and likely to be a selling point to newbies looking for to try linux. In my humble opinion much more should be made of this.
