Hide Desktop Icons in 19.04
Just installed 19.04 and it looks very sharp. I’m looking for a way to hide desktop icons, as was previously available in desktop settings. I might simply be missing it.
Thanks for any help!
Use the following:
gsettings set org.nemo.desktop show-desktop-icons false
logout and login
Thank you, that did it!
I’m not sure if this is the appropriate place for a feature request, but I really liked the ability to do that on a graphical interface, as I’m not as quick in the terminal. Thanks for listening, and for the solution via terminal!
Its something I am considering for the 20.04 LTS dev cycle. It all depends whether we stick with nemo-desktop for the desktop icons solution or another solution such as desktopfolder.
@fossfreedom @openfield I already have an applet for toggling desktop icons for nautilus for personal use. Just need to change a few chars for nemo. Post it?
Sure. Think people will love that.
Obviously here I am talking about a patch the budgie-desktop-settings to re-enable the previous desktop tab but for Nemo etc.
Ah, ok. WIll post this one:
afbeelding
in a sec.
@openfield might come in handy: an applet to toggle desktop icons. See the readme for setup: https://github.com/UbuntuBudgie/experimental/tree/master/unreleased_ready_to_use/toggledesktopicons
Tried it … really cool :slight_smile:
