Hot Corners. I have no choice in Budgie Applets
Hi. I cannot start the Hot Corners applet. I have no choice. I tried with: sudo apt-get install budgie-hotcorners-applet Unfortunately, nothing works.
Below are my parameters:
Ubuntu 21.04
trxo@trxo-Lenovo-Legion-5-15IMH05H:~ budgie-panel --replace& [1] 2902 trxo@trxo-Lenovo-Legion-5-15IMH05H:~
(budgie-panel:2902): Indicator-Applet-WARNING **: 13:52:30.789: unable to open indicator service file directory: Błąd podczas otwierania katalogu „/usr/share/unity/indicators”: Nie ma takiego pliku ani katalogu
sys:1: Warning: g_file_test: assertion ‘filename != NULL’ failed
sys:1: Warning: …/…/…/gobject/gsignal.c:1760: parameter 1 of type ‘SynapseResultSet’ for signal “SynapseDataSink::search-done” is not a value type
** (budgie-panel:2902): CRITICAL **: 13:52:30.896: Client.vala:88: Initializing client failed
** Message: 13:52:30.955: libsession.vala:45: DESKTOP_AUTOSTART_ID not set, session registration may be broken (not running budgie-desktop?)
Dont forget to logout and login after installing any applets
