Hi everyone.
I’ve just install ubuntu budgie on my macbook air and i would like to activate active corners.
The budgie applet called “coin raccourcis” is installed but doesn’t work.
How can i enable it ?
Thank you for your answer.
Pascal
Hi everyone.
Pascal
Hi Pascal, you need to add it to the panel from Budgie Settings, then you can set your actions from the applet’s menu in the panel.
Try log out and back in, as far I know, installing applets need we restart session, then ----------> budgie desktop settings
True, true. If you just installed them, log out/in.
Wow ! very quick answer ! thank you very much !
