How to activate system sounds at startup
Do you mean the sound at login ?
Maybe install gnome-session-canberra ?
Hi, I have tried everything I installed canberra-gtk-play from the terminal then I created the command for the startup application but no sound.
Only the system ones that can be selected but not the access sound work.
Not sure what you mean by system sounds.
Are you referring to alerts? Menu - Sounds … have you checked which things are muted?
Yes I checked all the sound I would like to make is classic when I turn on the computer
Have you installed gnome-session-canberra package ?
Thanks I solved it by entering the path on the startup application and now it works!
