I just installed budgie on my laptop. But for some reason when I boot up the grub boot loader appears.
I don’t want this behavior. I’m not dual booting with windows or anything.
How can I get rid of this?
odd. very odd.
Does this help?
The advice in that said basically says to change the timeout option.
However mine is already 0.
/etc/default$ cat grub
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=lsb_release -i -s 2> /dev/null || echo Debian
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash”
GRUB_CMDLINE_LINUX=""
#GRUB_BADRAM=“0x01234567,0xfefefefe,0x89abcdef,0xefefefef”
#GRUB_TERMINAL=console
#GRUB_GFXMODE=640x480
#GRUB_DISABLE_LINUX_UUID=true
#GRUB_DISABLE_RECOVERY=“true”
#GRUB_INIT_TUNE=“480 440 1”
I completely wiped my disks and reinstalled budgie and the problem went away. I’m not sure what happened. Maybe leftovers from my previous kubuntu installation. Anyway I wish to close this thread.
