Grub Menu issue
I recently upgraded from 24.04.0 to 24.04.1 and it has left behind an advanced options entry in my grub menu. Running grub customizer doesn’t fix this issue. How do I get rid of that entry?
Hi @macgrioghair!
This should work :
sudo os-prober && sudo update-grub
Unfortunately it didn’t. All it seems to have in that entry are a couple of memtests
I thought they were advanced options for old kernels.
As for memory tests, click on each of them in Grub Customizer, then on ‘Remove’. Save changes. They should no longer appear in the menu.
The same goes for unwanted advanced options.
In any case, it works on my system.
