My hard disk partition (NTFS) is mounted with the only read writes.
I have the fix which I have to do every time I restart:
sudo ntfsfix /dev/sda1
sudo mount -o rw /dev/sda1
Does anybody know how to make this permanent?
You will need to create a manual fstab entry as per the ubuntu wiki
Great, thank you!
Solved it with adding a parameter rw in fstab.
