Hi, i’ve deleted a folder thinking that isn’t would happen nothing, but my theme gtk is messed up, the bar of titles is white even when I put on dark theme, and the pocillo theme isn’t showing to select in settints of budgie desktop, even reinstalling. How do I reset my gtk theme ?
what folder did you delete?
theme of /usr/share/themes
Try
sudo apt install --reinstall ubuntu-budgie-themes
logout/login
You have some of the default themes missing:
sudo apt install --reinstall libgtk2.0-common libgtk-3-common
sudo apt install --reinstall gnome-themes-extra gnome-themes-extra-data
Then logout/login.
thank you one more time !
