What do you mean?
‘retain the standard…’
standard (default) is Pocillo (i.e. gtkrc ), Pocillo-dark (gtkrc-dark) and Pocillo-light (gtkrc-light)
Yeah, okay. Before filing a PR, can you test?
https://drive.google.com/open?id=1qXPtD_3fMfw6osq8nrZhT8I8evkcCJfT
Sorry - I don’t open “random” google drive stuff for security reasons.
If you upload to your fork on github I can have a look.
Be sure to use what’s in the pocillo-standard-new folder, not anything in src
I dunno how to fix that, I can give you collaborator access to my fork if you have any ideas
not off the top of my head.
Well, I sent you a collaborator request anyways: https://github.com/gsbhasin123/pocillo-gtk-theme/invitations also I think resizing the image it gave you the path to might help, if you want to try @fossfreedom
Have you tried resizing it?
I havent looked. I have high priority budgie desktop crash issues I need to resolve before looking into it.
In that case, I’ll try myself
@fossfreedom so apparently I mixed Arc and Materia elements. Fixed problem. I will push after I have made variants for pocillo-light and pocillo-standard, the same gtk2 can be used for slim versions
@fossfreedom everything is fixed
I’ve added all six Pocillo variants (dark, light, regular, dark slim, light slim, regular slim) and patched them for GTK2, and fixed that bug you experienced. Should be full Material now - please test when you have time, and let me know if any bugs exist. https://github.com/gsbhasin123/pocillo-gtk-theme
sure - however the current work cannot be merged - you have been updating the compiled version of the theme. To-do the merge, the updates to the current source needs to be done - then the compilation will create the variants.
Okay, I can do that, but I can’t find the slim code. e.g there’s no https://github.com/UbuntuBudgie/pocillo-gtk-theme/tree/master/src/gtk-2.0 in here.
There are no current slim variants for GTK 2, only for GTK 3 - the pocillo and pocillo-slim themes use the same GTK 2 theme files
Ah, never mind. I’ll do it later.
@fossfreedom can’t figure it out… Would you mind helping add these to the sources when possible? What I’ve tried results in some Windows98 clone gtk2 theme being applied. I used ./apply to install.
help appreciated
