Try to use Libre Calc instead of Excel that I have used for years. Many new things…
For instance do I want so do something simple as scaling the page before print out.
But can not see any menu to set it up?
Attached are screenshot of my title bar.
Have you been playing with layouts - possibly using one with the global menu? I note you previously said you now using a bottom bar - the global menu applet will still be active … but not visible. You need to logout and login to fully deactivate the global menu applet and things like calc should be ok again.
Thanks again.
Log out and in did the trick.
Menues are now back
