The GNU GRUB window shows up, I select Try or Install Ubuntu Budgie.
The login stage that never accepts my data even though I enter it correctly.
I would provide each item on the list with a screenshot, but new users are only allowed to insert 1 media file per post.
I purposely came up with the simplest username and password possible so that I wouldn’t make mistake. Nevertheless, I still get “Invalid password” error.
Please describe what values you chose at each stage. We need to see if we can reproduce your issue.
I have never seen this myself. Selected english uk, standard keyboard, standard install (no custom options) username with no special characters and password of no special characters
It’s interesting that the LTS version (22.04) works fine. I use the same username and password for it, all other values are also similar. It never returned me the “Invalid password” error.
However, I’d like to use Budgie Standard.
Thank you, having Skip Unattended Installation on did help. Had to go through the manual installation, but at least I didn’t get looped on the login screen.
Even though Standard version has the latest features, I find LTS to be more reliable and predicable.
