I have a problem with the Login Window in the latest version of Budgie. I open it and change the wallpaper and reboot. Once Budgie opens, the new login theme appears for a second and then the image reverts to the Desktop background wallpaper.
Any suggestions?
Use menu - login window and uncheck the user background checkbox
Sorry, I can’t find user background checkbox in the login window list of options?
I am using the same setup procedure as I did for Ubuntu Budgie 18.10. I had no problem with that version at all.
ah - its a bug.
Please file a bug-report on launchpad and I’ll get a fix out that you can test in due course.
ubuntu-bug lightdm-settings
EDIT: FYI it is this bug report and the commit referenced needs to be backported
