Mouse Double-Click Speed
I want to make this a bit slower, I don’t suppose I can use gnome-tweaks, is there an equivalent for Budgie?
Use dconf-editor:
Increasing the double click time from 400 to say 500 or 600 will slow the click speed down slightly
I’d forgotten about dconf-editor - I haven’t needed it, unlike with some other distros :). However, I don’t seem to get any of the options:
Go to the top of the tree and navigate from org to gnome downwards
Sorry, I thought I was at the top, I didn’t realise what the tick-thing top left did. Now sorted, thanks again!
Heads up for @ChrisOfBristol, gnome tweaks can be installed and used just the same on UB, only gnome specific stuff (extensions mainly) is missing.
@ codic I didn’t think of trying that either, as Budgie isn’t Gnome. However it hasn’t got double-click speed.
Oh ok, does that work in gnome?
No idea, I use Budgie.
Ok, was asking because
So I thought you switched over from GNOME
I don’t know how you got that impression. If you can point out to me where I Implied that let me know and I will remove/clarify it.
Just because you said “I don’t suppose I can use gnome-tweaks”, I thought that implied that you were used to the GNOME way of doing stuff, therefore, you were previously on GNOME.
@codic This exchange is in danger of collapsing into an improbability vortex, so I’ll opt out :slight_smile:
