Where can I set a single click instead of a double click when I click on files and folders?
What are you using? Nautilus i.e. 18.04 or Nemo I.e. 19.10?
Nemo, but I don’t see am menu
Looking for the gui way, but from terminal: gsettings set org.nemo.preferences click-policy single should do the job.
Just press the alt key to display the menu. Then can choose the preferences menu option and choose the click policy from there.
Nemo is i.e. 19.04 or 19.10 right?
19.10
the ALT key was the solution
Thank you
