Nemo double click goes back
In the file manager, when I double click outside a folder/application icon while a folder/application is selected it sends me back to the previous directory. This is annoying when I miss click outside a folder/application by mistake.
When no folder/application is selected and I double click outside nothing happens.
Video to explain the issue better: https://streamable.com/3yiwa
Think this is your issue https://github.com/linuxmint/nemo/issues/2167
better explanation on the commit message https://github.com/linuxmint/nemo/commit/f84f53b21c1fdcb0f3f6d40a820b572124c9ae26
If you can test our 20.04 daily ISO (live session) which will have nemo v4.2.3 then it will confirm whether this is indeed the issue and that it has been fixed.
I would like to remove this action completely, is that possible? So nothing happens if I click on the background?
Have you tested the version on the daily ISO?
Not sure how to do that, will try later. But I thought maybe there was a background click action that sends you to the previous directory, guess not and its just a bug?
You’ll know if its a bug or not by testing the daily ISO - just download the ISO, write it to a USB stick and boot into it.
Still happens on 20.04 btw. Maybe it’s just a setting that when you double click an empty space it goes one folder up? Can I disable that?
This?
Open nemo>preferences> behavior and check “Double-click on a blank area to go to the parent folder”.
That was it after all this time :smiley:
I couldn’t find the preferences for some reason.
Thanks.
You will probably want to disable it for root as well.
I find it extremely annoying and non-intuitive, a misclick pushes you up sometimes without you noticing it, would vote to disable it by default.
Since you will probably forget this setting if you ever reinstall Budgie, you might want to make a note of it or add it to a post-install script as I did here:
