Mpv not appearing in menu
I just installed mpv, but its desktop file (mpv.desktop) does not appear in menu.
I checked if the file has any NoDisplay set to true, but I found nothing so far
This is the mpv.desktop file: https://ghostbin.co/paste/9e83p
Thanks!
We deliberately hide that since it confuses people … gnome mpv (now celluloid) and mpv
So if you want it in you menu you need to put your own in .local/share/applications
Thanks! But sadly, it does not appears in configurations so I would set it as default video player
Last time I used gnome mpv I had some problems with video accelaration
Also, is celluloid in the repos? Thanks!
Yes. It’s in the 20.04 repos and it’s the default video player on our iso
Can I install it in 19.10?
You will need to look to see if there is a snap/flatpak or ppa available
https://celluloid-player.github.io/installation.html shows
flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
flatpak install flathub io.github.GnomeMpv
or the dev version:
flatpak install https://dl.tingping.se/flatpak/gnome-mpv.flatpakref
