Hello,
when here :
you can add or remove autostart apps but no way to check or to modify what’s already there.
For example, I wanted to add an icon and a comment to Bluetooth OFF, I had to modify the desktop.file in ~/.config/autostart
Is this intended behaviour ? A cog near the red (-) might be useful to display the same dialog box as (+) on selected item to eventually modify ( a command, a path, a comment… )
I also suspect a problem of localization with the desktop.file created for a command : where Comment= was expected, it was its french translation Description=
