Hola, recién instale Ubuntu budgie en mi HP pavilion x360 pero tengo problemas con la red de wifi ya que no reconoce ningún adaptador inalámbrico. ¿Alguien amablemente podría ayudarme?
Sorry I dont speak your language…
In general connect your laptop using a wired connection. Then open Menu - additional drivers and select the drivers tab. See if there are additional drivers for your wifi to install.
me dice que no hay controladores adicionales disponibles y que no se están usando controladores privativos.
This script may help with trouble shooting.
########## wireless info START ##########
Report from: 28 Aug 2019 12:52 CDT -0500
Booted last: 28 Aug 2019 00:00 CDT -0500
Script from: 22 Oct 2018 03:34 UTC +0000
release
Distributor ID: Ubuntu
Description: Ubuntu 18.04.3 LTS
Release: 18.04
Codename: bionic
kernel
Linux 5.0.0-25-generic #26~18.04.1-Ubuntu SMP Thu Aug 1 13:51:02 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=1
desktop
Budgie Desktop
lspci
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:d723]
Subsystem: Hewlett-Packard Company Device [103c:8319]
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0bda:b009 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 0bda:58eb Realtek Semiconductor Corp.
Bus 001 Device 015: ID 22b8:2e24 Motorola PCS
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
PCMCIA card info
rfkill
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
secure boot
‘mokutil’ is not installed (package “mokutil”).
lsmod
hp_wmi 16384 0
wmi_bmof 16384 0
intel_wmi_thunderbolt 20480 0
sparse_keymap 16384 2 hp_wmi,intel_vbtn
wmi 28672 3 hp_wmi,intel_wmi_thunderbolt,wmi_bmof
interfaces
[/etc/network/interfaces]
auto lo
iface lo inet loopback
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback brd
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
7: enp0s20f0u1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
link/ether <MAC ‘enp0s20f0u1’ [IF1]> brd
inet 192.168.42.154/24 brd 192.168.42.255 scope global dynamic noprefixroute enp0s20f0u1
valid_lft 3192sec preferred_lft 3192sec
inet6 fe80::8140:bf4f:f2d9:eb2d/64 scope link noprefixroute
iwconfig
enp0s20f0u1 no wireless extensions.
lo no wireless extensions.
route
default via 192.168.42.129 dev enp0s20f0u1 proto dhcp metric 100
169.254.0.0/16 dev enp0s20f0u1 scope link metric 1000
192.168.42.0/24 dev enp0s20f0u1 proto kernel scope link src 192.168.42.154 metric 100
resolv.conf
[777 root ‘/etc/resolv.conf’ -> ‘…/run/systemd/resolve/stub-resolv.conf’]
nameserver 127.0.0.53
options edns0
network managers
Installed:
NetworkManager
Running:
root 1035 1 0 Aug27 ? 00:00:01 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
GENERAL.DEVICE: enp0s20f0u1
GENERAL.TYPE: ethernet
GENERAL.NM-TYPE: NMDeviceEthernet
GENERAL.VENDOR: motorola
GENERAL.PRODUCT: moto e5 play
GENERAL.DRIVER: rndis_host
GENERAL.DRIVER-VERSION: 22-Aug-2005
GENERAL.FIRMWARE-VERSION: RNDIS device
GENERAL.HWADDR: <MAC ‘enp0s20f0u1’ [IF1]>
GENERAL.MTU: 1500
GENERAL.STATE: 100 (connected)
GENERAL.REASON: 0 (No reason given)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/net/enp0s20f0u1
GENERAL.IP-IFACE: enp0s20f0u1
GENERAL.IS-SOFTWARE: no
GENERAL.NM-MANAGED: yes
GENERAL.AUTOCONNECT: yes
GENERAL.FIRMWARE-MISSING: no
GENERAL.NM-PLUGIN-MISSING: no
GENERAL.PHYS-PORT-ID: –
GENERAL.CONNECTION: Conexión cableada 1
GENERAL.CON-UUID: a5f13d8e-dd62-3171-b892-db0157ab6ad0
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/6
GENERAL.METERED: yes (guessed)
CAPABILITIES.CARRIER-DETECT: yes
CAPABILITIES.SPEED: unknown
CAPABILITIES.IS-SOFTWARE: no
CAPABILITIES.SRIOV: no
WIRED-PROPERTIES.CARRIER: on
IP4.ADDRESS[1]: 192.168.42.154/24
IP4.GATEWAY: 192.168.42.129
IP4.ROUTE[1]: dst = 0.0.0.0/0, nh = 192.168.42.129, mt = 100
IP4.ROUTE[2]: dst = 192.168.42.0/24, nh = 0.0.0.0, mt = 100
IP4.ROUTE[3]: dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
IP4.DNS[1]: 192.168.42.129
DHCP4.OPTION[1]: requested_subnet_mask = 1
DHCP4.OPTION[2]: requested_rfc3442_classless_static_routes = 1
DHCP4.OPTION[3]: subnet_mask = 255.255.255.0
DHCP4.OPTION[4]: domain_name_servers = 192.168.42.129
DHCP4.OPTION[5]: ip_address = 192.168.42.154
DHCP4.OPTION[6]: requested_static_routes = 1
DHCP4.OPTION[7]: dhcp_server_identifier = 192.168.42.129
DHCP4.OPTION[8]: requested_time_offset = 1
DHCP4.OPTION[9]: broadcast_address = 192.168.42.255
DHCP4.OPTION[10]: dhcp_rebinding_time = 3026
DHCP4.OPTION[11]: requested_interface_mtu = 1
DHCP4.OPTION[12]: requested_domain_name_servers = 1
DHCP4.OPTION[13]: dhcp_message_type = 5
DHCP4.OPTION[14]: dhcp_renewal_time = 1676
DHCP4.OPTION[15]: routers = 192.168.42.129
DHCP4.OPTION[16]: requested_broadcast_address = 1
DHCP4.OPTION[17]: requested_domain_name = 1
DHCP4.OPTION[18]: requested_routers = 1
DHCP4.OPTION[19]: expiry = 1567017922
DHCP4.OPTION[20]: host_name = hp-sharon
DHCP4.OPTION[21]: requested_wpad = 1
DHCP4.OPTION[22]: requested_netbios_scope = 1
DHCP4.OPTION[23]: requested_ms_classless_static_routes = 1
DHCP4.OPTION[24]: requested_netbios_name_servers = 1
DHCP4.OPTION[25]: network_number = 192.168.42.0
DHCP4.OPTION[26]: requested_domain_search = 1
DHCP4.OPTION[27]: next_server = 192.168.42.129
DHCP4.OPTION[28]: requested_ntp_servers = 1
DHCP4.OPTION[29]: vendor_encapsulated_options = ANDROID_METERED
DHCP4.OPTION[30]: dhcp_lease_time = 3600
DHCP4.OPTION[31]: requested_host_name = 1
IP6.ADDRESS[1]: fe80::8140:bf4f:f2d9:eb2d/64
IP6.GATEWAY: –
IP6.ROUTE[1]: dst = ff00::/8, nh = ::, mt = 256, table=255
IP6.ROUTE[2]: dst = fe80::/64, nh = ::, mt = 256
IP6.ROUTE[3]: dst = fe80::/64, nh = ::, mt = 100
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/{9}
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: a5f13d8e-dd62-3171-b892-db0157ab6ad0 | Conexión cableada 1
GENERAL.DEVICE:
GENERAL.TYPE: bt
GENERAL.NM-TYPE: NMDeviceBt
GENERAL.VENDOR: –
GENERAL.PRODUCT: –
GENERAL.DRIVER: bluez
GENERAL.DRIVER-VERSION: –
GENERAL.FIRMWARE-VERSION: –
GENERAL.HWADDR:
GENERAL.MTU: 0
GENERAL.STATE: 30 (disconnected)
GENERAL.UDI: /org/bluez/hci0/dev_58_D9_C3_AD_52_B1
GENERAL.IP-IFACE: –
GENERAL.CONNECTION: –
GENERAL.CON-UUID: –
GENERAL.CON-PATH: –
GENERAL.METERED: unknown
CAPABILITIES.CARRIER-DETECT: no
BLUETOOTH.CAPABILITIES: NAP
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/{5}
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: a1cafa66-e48b-4e04-9564-d71dbf92b2c6 | Red Sharon
NetworkManager.state
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]]
[connection]
wifi.powersave = 3
[[/etc/NetworkManager/NetworkManager.conf]]
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
[device]
wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]]
[main]
dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]]
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:wwan
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]]
[device-mac-addr-change-wifi]
match-device=driver:rtl8723bs,driver:rtl8189es,driver:r8188eu,driver:8188eu,driver:eagle_sdio,driver:wl
wifi.cloned-mac-address=preserve
ethernet.cloned-mac-address=preserve
NetworkManager profiles
Netplan config
[/etc/netplan/01-network-manager-all.yaml]
network:
version: 2
renderer: NetworkManager
iw reg get
Region: America/Mexico_City (based on set time zone)
global
country 00: DFS-UNSET
(2402 - 2472 @ 40), (6, 20), (N/A)
(2457 - 2482 @ 20), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (6, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (6, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
iwlist channels
enp0s20f0u1 no frequency information.
lo no frequency information.
iwlist scan
enp0s20f0u1 Interface doesn’t support scanning.
lo Interface doesn’t support scanning.
module infos
module parameters
/etc/modules
modprobe options
[/etc/modprobe.d/amd64-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod)
&& /sbin/modprobe -r mac80211
rc.local
grep: /etc/rc.local: No such file or directory
pm-utils
udev rules
dmesg
[12407.601692] Bluetooth: hci0: RTL: rtl: loading rtl_bt/rtl8723d_config.bin
[14721.854853] rndis_host 1-1:1.0 enp0s20f0u1: renamed from usb0
[14723.407219] rndis_host 1-1:1.0 enp0s20f0u1: unregister ‘rndis_host’ usb-0000:00:14.0-1, RNDIS device
[14723.514595] rndis_host 1-1:1.0 enp0s20f0u1: renamed from usb0
########## wireless info END ############
Hola, esto es lo que obtuve. Pero no sé como solucionarlo.
This has been addressed @ Ask Ubuntu. That’s all I can offer.
