NVIDIA Budgie Applet?
Just wondering if is there a plan to add as budgie applet a nivdia temperature indicator as seen from gnome extensions? :slight_smile:
You could use the system monitor applet with a custom script that parses out the gpu temperature from the output of nvidia-smi
Thx answer… I figured out how to do it on explanation number 53 and working all good :slight_smile:
explanation number 53? can you copy paste the web link please?
Sorry, forgot sending link:https://askubuntu.com/questions/34449/how-to-see-the-video-card-temperature-nvidia-ati-intel
Command used is:
user@box:~$ nvidia-smi --query-gpu=temperature.gpu --format=csv,noheader
