I’ve installed the System Monitor Applet from the Budgie Welcome Menu, logged out and then logged in, but the applet isn’t showing up in the Add Applet list.
How can I fix this?
There are two applets called System Monitor Applet in Budgie Welcome. I think the issue here is that the second one, the one that has a description that says “Customize and display system information on the panel” installs to the wrong place.
It seems to install to
/usr/usr/lib/budgie-desktop/plugins/budgiesysmonitor
instead of
Anyways, if this is the issue, you can just copy or move it to the right spot:
sudo mv /usr/usr/lib/budgie-desktop/plugins/budgiesysmonitor /usr/lib/budgie-desktop/plugins/
Then logout and login
Thx. Surprised. Easy enough fix. Will be fix on the next few hours. Just update tomorrow
