NVidia xorg.conf issue
Hello everybody.
I just installed Ubuntu budgie.
system information below:
apanta@apanta-desktop:~$ inxi -Fraxxx
System:
  Host: apanta-desktop Kernel: 5.19.0-31-generic arch: x86_64 bits: 64
    compiler: N/A parameters: BOOT_IMAGE=/boot/vmlinuz-5.19.0-31-generic
    root=UUID=594b1e7c-6995-4f39-b285-09bdbb77954d ro quiet splash
  Desktop: Budgie v: 10.6.4 info: budgie-panel, plank wm: budgie-wm
    dm: LightDM v: 1.30.0 Distro: Ubuntu 22.10 (Kinetic Kudu)
Machine:
  Type: Desktop Mobo: ASRock model: K10N78FullHD-hSLI..
    serial: <superuser required> BIOS: American Megatrends v: P2.30
    date: 04/30/2010
CPU:
  Info: model: AMD Athlon 64 X2 5200+ bits: 64 type: MCP arch: K8 level: v1
    built: 2005-08 process: AMD 65nm family: 0xF (15) model-id: 0x6B (107)
    stepping: 2 microcode: N/A
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 256 KiB
    desc: d-2x64 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
  Speed (MHz): avg: 1000 min/max: 1000/2700 scaling: driver: powernow-k8
    governor: schedutil cores: 1: 1000 2: 1000 bogomips: 10800
  Flags: ht lm nx pae sse sse2 sse3 svm
  Vulnerabilities:
  Type: itlb_multihit status: Not affected
  Type: l1tf status: Not affected
  Type: mds status: Not affected
  Type: meltdown status: Not affected
  Type: mmio_stale_data status: Not affected
  Type: retbleed status: Not affected
  Type: spec_store_bypass status: Not affected
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
    sanitization
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
    PBRSB-eIBRS: Not affected
  Type: srbds status: Not affected
  Type: tsx_async_abort status: Not affected
Graphics:
  Device-1: NVIDIA GF106 [GeForce GTS 450] driver: nvidia v: 390.157
    alternate: nvidiafb,nouveau,nvidia_drm non-free: series: 390.xx+
    status: legacy-active (EOL~late 2022) arch: Fermi code: GF1xx
    process: 40/28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 02:00.0 chip-ID: 10de:0dc4 class-ID: 0300
  Device-2: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-1:2 chip-ID: 046d:081b class-ID: 0102 serial: 23CC4900
  Display: x11 server: X.Org v: 1.21.1.4 compositor: budgie-wm driver: X:
    loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 339x271mm (13.35x10.67")
    s-diag: 434mm (17.09")
  Monitor-1: HDMI-0 pos: primary res: 1280x1024 hz: 60 dpi: 203
    size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
  Monitor-2: VGA-0 pos: primary res: 1280x1024 dpi: 86
    size: 380x300mm (14.96x11.81") diag: 484mm (19.06") modes: N/A
  OpenGL: renderer: GeForce GTS 450/PCIe/SSE2 v: 4.6.0 NVIDIA 390.157
    direct render: Yes
Audio:
  Device-1: NVIDIA MCP72XE/MCP72P/MCP78U/MCP78S High Definition Audio
    vendor: ASRock driver: snd_hda_intel bus-ID: 1-1:2 v: kernel
    bus-ID: 00:07.0 chip-ID: 046d:081b class-ID: 0102 chip-ID: 10de:0774
    class-ID: 0403 serial: 23CC4900
  Device-2: NVIDIA GF106 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 02:00.1
    chip-ID: 10de:0be9 class-ID: 0403
  Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
  Device-4: TerraTec GmbH Aureon Dual USB type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-1:2 chip-ID: 0ccd:0077
    class-ID: 0300
  Sound Server-1: ALSA v: k5.19.0-31-generic running: yes
  Sound Server-2: PipeWire v: 0.3.58 running: yes
Network:
  Device-1: NVIDIA MCP77 Ethernet vendor: ASRock K10N78FullHD-hSLI R3.0
    driver: forcedeth v: kernel port: a880 bus-ID: 00:0a.0 chip-ID: 10de:0760
    class-ID: 0200
  IF: enp0s10 state: down mac: 00:19:66:95:bb:3a
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    vendor: TP-LINK TG-3468 driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e800 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: 50:3e:aa:0d:94:6e
Drives:
  Local Storage: total: 4.32 TiB used: 583.71 GiB (13.2%)
  SMART Message: Required tool smartctl not installed. Check --recommends
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: SSD serial: S2RBNXAH108619N rev: 2B6Q scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1ER164
    size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: Z4Z1QG3Y rev: CC25 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST31000528AS
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: 9VP9W7X3 rev: CC38 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT250MX500SSD1
    size: 232.89 GiB block-size: physical: 4096 B logical: 512 B
    speed: 3.0 Gb/s type: SSD serial: 2143E5DBAF7B rev: 043 scheme: MBR
  ID-5: /dev/sde maj-min: 8:64 vendor: Crucial model: CT1000BX500SSD1
    type: SSD serial: 2205E6065CFA rev: 060 scheme: MBR
Partition:
  ID-1: / raw-size: 50.3 GiB size: 49.21 GiB (97.83%) used: 10.8 GiB (22.0%)
    fs: ext4 dev: /dev/sde2 maj-min: 8:66
Swap:
  Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 7.45 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda1 maj-min: 8:1
Sensors:
  System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 48 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Repos:
  Packages: 1959 pm: dpkg pkgs: 1947 libs: 1011
    tools: apt,apt-get,gnome-software pm: snap pkgs: 12
  Active apt repos in: /etc/apt/sources.list
    1: deb http://it.archive.ubuntu.com/ubuntu/ kinetic main restricted
    2: deb http://it.archive.ubuntu.com/ubuntu/ kinetic-updates main restricted
    3: deb http://it.archive.ubuntu.com/ubuntu/ kinetic universe
    4: deb http://it.archive.ubuntu.com/ubuntu/ kinetic-updates universe
    5: deb http://it.archive.ubuntu.com/ubuntu/ kinetic multiverse
    6: deb http://it.archive.ubuntu.com/ubuntu/ kinetic-updates multiverse
    7: deb http://it.archive.ubuntu.com/ubuntu/ kinetic-backports main restricted universe multiverse
    8: deb http://security.ubuntu.com/ubuntu kinetic-security main restricted
    9: deb http://security.ubuntu.com/ubuntu kinetic-security universe
    10: deb http://security.ubuntu.com/ubuntu kinetic-security multiverse
Info:
  Processes: 203 Uptime: 1h 4m wakeups: 2520 Memory: 7.76 GiB used: 1.67 GiB
  (21.6%) Init: systemd v: 251 target: graphical (5) default: graphical
  tool: systemctl Compilers: gcc: N/A Shell: Bash v: 5.2.2 running-in: tilix
  inxi: 3.3.21
My video card is a workforce GTS450. I set the two connected displays to “Duplicate” and it works fine. Then I tried to save the configured settings but it won’t let me save them in the /etcX11/xorg.conf file as such file doesn’t exist.
Using nemo I created the empty xorg.conf document and then tried to save again, but without success.
The driver is correct (390.157).
the answer I get is:
[url=https://postimages.org/][/url]
Can you suggest me how to work to solve the problem? Thank you
How are you launching nvidia settings?
Use pkexec with the app name since the file is being written to a system area that pkexec will grant
Before launch nvidia via the program icon.
Now via terminale:
apanta@apanta-desktop:~$ pkexec '/usr/share/applications/nvidia-settings.desktop'
But when I press enter the result is:
Error executing /usr/share/applications/nvidia-settings.desktop: Permission denied
I also tried:
apanta@apanta-desktop:~$ pkexec /usr/bin/nvidia-settings
ERROR: The control display is undefined; please run `/usr/bin/nvidia-settings
       --help` for usage information.
apanta@apanta-desktop:~$ /usr/bin/nvidia-settings
       --help
(nvidia-settings:4470): GLib-GObject-CRITICAL **: 19:47:52.626: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 19:47:53.057: PRIME: No offloading required. Abort
** Message: 19:47:53.057: PRIME: is it supported? no
VALIDATION ERROR:  Data incomplete in file /etc/X11/xorg.conf.
At least one Device section is required.
WARNING:  Unable to parse X.Org version string.
Package xorg-server was not found in the pkg-config search path.
Perhaps you should add the directory containing `xorg-server.pc'
to the PKG_CONFIG_PATH environment variable
No package 'xorg-server' found
Error executing /usr/share/screen-resolution-extra/nvidia-polkit: Permission denied
ERROR: Unable to open X config file '/etc/X11/xorg.conf' for writing.
--help: comando non trovato
I spotted this
Do you have a file /usr/share/screen-resolution-extra/nvidia-polkit ?
If so the suggested fix is
sudo chmod u+x /usr/share/screen-resolution-extra/nvidia-polkit
The file exists, but when I give the command, this is the response
apanta@apanta-desktop:~$ sudo chmod u+x /usr/share/screen-resolution-extra/nvidia-polkit
sudo: /etc/sudo.conf is world writable
sudo: /etc/sudoers è scrivibile da tutti
sudo: nessuna sorgente valida di sudoers trovata, uscita
sudo: errore nell'inizializzare il plugin di audit sudoers_audit
You have bigger issues than the nvidia settings.
You seem to have messed up your sudo rights.
A more generic ubuntu forum can help here. It isnt a budgie specific issue
askubuntu.com and ubuntuforums.org
After several tries, suddenly the command worked and then I was able to save the settings. Thanks for your help
How can I mark the post as solved?
Even though I solved the problem, I preferred to switch to a fresh install of Ubuntu budgie 22.04 lts.
Installed without problems, with nvidia drivers and everything works perfectly.
apanta@apanta-desktop:~$ inxi -FZA
System:
  Host: apanta-desktop Kernel: 5.19.0-32-generic x86_64 bits: 64
    Desktop: Budgie 10.6.1 Distro: Ubuntu 22.04.2 LTS (Jammy Jellyfish)
Machine:
    date: 04/30/2010
CPU:
  Info: dual core model: AMD Athlon 64 X2 5200+ bits: 64 type: MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 1000 min/max: 1000/2700 cores: 1: 1000 2: 1000
Graphics:
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
    gpu: nvidia resolution: 1: 1280x1024~60Hz 2: 1280x1024
Audio:
  Sound Server-1: ALSA v: k5.19.0-32-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: NVIDIA MCP77 Ethernet driver: forcedeth
    driver: r8169
Drives:
  Local Storage: total: 4.32 TiB used: 750.83 GiB (17.0%)
  ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
  ID-2: /dev/sdb vendor: Seagate model: ST2000DM001-1ER164 size: 1.82 TiB
  ID-3: /dev/sdc vendor: Seagate model: ST31000528AS size: 931.51 GiB
  ID-4: /dev/sdd vendor: Crucial model: CT250MX500SSD1 size: 232.89 GiB
  ID-5: /dev/sde vendor: Crucial model: CT1000BX500SSD1 size: 931.51 GiB
Partition:
  ID-1: / size: 49.21 GiB used: 10 GiB (20.3%) fs: ext4 dev: /dev/sde2
Swap:
    dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 28.0 C mobo: N/A gpu: nvidia temp: 39 C
Info:
  Processes: 226 Uptime: 1m Memory: 7.76 GiB used: 1.21 GiB (15.6%)
  Shell: Bash inxi: 3.3.13
I would advise that you choose an alternative driver. Nvidea ended support for 390 at the end of last year.
FYI
true true. The OP though I think is limited - its either use the 390 legacy driver - or just use the out of the box opensource nouveau driver. The graphics model is too old for the newer nvidia drivers.
Nouveau is a good alternative now. Overheating issues seem to have been fixed.
Thanks again for your patience
