I am using Budgie 23.10. My system failed on an upgrade, and now it says I have errors in:
Memtest86+
Grub-pc and
Linux-image-6.6.0-14-generic
It is also throwing up an error on:
Linux-image-5.15.0-88-generic
I am thinking I need to get rid of this last image, but any feedback is greatly appreciated. I will post any data that people request.
Thank you very much,
Steven
In a terminal please copy paste the output of the following
sudo apt update && sudo apt full-upgrade
This is everything:
macgrioghair@macgrioghair-ThinkPad-T420:~$ sudo apt update && sudo apt full-upgrade
[sudo] password for macgrioghair:
Get:1 http://archive.ubuntu.com/ubuntu noble InRelease [256 kB]
Hit:2 http://security.ubuntu.com/ubuntu noble-security InRelease
Hit:3 http://archive.ubuntu.com/ubuntu noble-updates InRelease
Hit:4 http://archive.ubuntu.com/ubuntu noble-backports InRelease
Get:5 http://archive.ubuntu.com/ubuntu noble/main Sources [1,386 kB]
Get:6 http://archive.ubuntu.com/ubuntu noble/multiverse Sources [291 kB]
Get:7 http://archive.ubuntu.com/ubuntu noble/universe Sources [19.7 MB]
Get:8 http://archive.ubuntu.com/ubuntu noble/main i386 Packages [1,058 kB]
Get:9 http://archive.ubuntu.com/ubuntu noble/main amd64 Packages [1,430 kB]
Get:10 http://archive.ubuntu.com/ubuntu noble/main Translation-en [518 kB]
Get:11 http://archive.ubuntu.com/ubuntu noble/multiverse i386 Packages [114 kB]
Get:12 http://archive.ubuntu.com/ubuntu noble/multiverse amd64 Packages [235 kB]
Get:13 http://archive.ubuntu.com/ubuntu noble/multiverse Translation-en [113 kB]
Get:14 http://archive.ubuntu.com/ubuntu noble/universe i386 Packages [8,521 kB]
Get:15 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages [15.0 MB]
Get:16 http://archive.ubuntu.com/ubuntu noble/universe Translation-en [6,025 kB]
Fetched 54.7 MB in 14s (3,919 kB/s)
Reading package lists... Done
Building dependency tree... Done
28 packages can be upgraded. Run 'apt list --upgradable' to see them.
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
libicu72
Use 'sudo apt autoremove' to remove it.
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
python2.7-minimal python2.7 libpython2.7-minimal libpython2.7-stdlib
Learn more about Ubuntu Pro at https://ubuntu.com/pro
The following packages will be REMOVED:
linux-image-5.15.0-88-generic
The following packages will be upgraded:
bind9-dnsutils bind9-host bind9-libs dnsutils gcc-14-base gcc-14-base:i386
geary language-pack-gnome-en libasan8 libatomic1 libatomic1:i386 libcc1-0
libgcc-s1 libgcc-s1:i386 libgfortran5 libgnutls30 libgomp1 libhwasan0
libitm1 liblsan0 libneon27 libneon27-gnutls libpcap0.8 libquadmath0
libstdc++6 libstdc++6:i386 libtsan2 libubsan1
28 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
4 not fully installed or removed.
Need to get 18.2 MB of archives.
After this operation, 11.9 MB disk space will be freed.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu noble/main amd64 language-pack-gnome-en all 1:24.04+20240203 [113 kB]
Get:2 http://archive.ubuntu.com/ubuntu noble/main i386 gcc-14-base i386 14-20240201-3ubuntu1 [46.4 kB]
Get:3 http://archive.ubuntu.com/ubuntu noble/main amd64 gcc-14-base amd64 14-20240201-3ubuntu1 [46.4 kB]
Get:4 http://archive.ubuntu.com/ubuntu noble/main amd64 libstdc++6 amd64 14-20240201-3ubuntu1 [795 kB]
Get:5 http://archive.ubuntu.com/ubuntu noble/main i386 libstdc++6 i386 14-20240201-3ubuntu1 [864 kB]
Get:6 http://archive.ubuntu.com/ubuntu noble/main i386 libgcc-s1 i386 14-20240201-3ubuntu1 [75.5 kB]
Get:7 http://archive.ubuntu.com/ubuntu noble/main amd64 libgcc-s1 amd64 14-20240201-3ubuntu1 [77.5 kB]
Get:8 http://archive.ubuntu.com/ubuntu noble/main i386 libatomic1 i386 14-20240201-3ubuntu1 [8,500 B]
Get:9 http://archive.ubuntu.com/ubuntu noble/main amd64 libatomic1 amd64 14-20240201-3ubuntu1 [10.5 kB]
Get:10 http://archive.ubuntu.com/ubuntu noble/main amd64 libubsan1 amd64 14-20240201-3ubuntu1 [1,171 kB]
Get:11 http://archive.ubuntu.com/ubuntu noble/main amd64 libtsan2 amd64 14-20240201-3ubuntu1 [2,731 kB]
Get:12 http://archive.ubuntu.com/ubuntu noble/main amd64 libquadmath0 amd64 14-20240201-3ubuntu1 [155 kB]
Get:13 http://archive.ubuntu.com/ubuntu noble/main amd64 liblsan0 amd64 14-20240201-3ubuntu1 [1,309 kB]
Get:14 http://archive.ubuntu.com/ubuntu noble/main amd64 libitm1 amd64 14-20240201-3ubuntu1 [29.1 kB]
Get:15 http://archive.ubuntu.com/ubuntu noble/main amd64 libhwasan0 amd64 14-20240201-3ubuntu1 [1,629 kB]
Get:16 http://archive.ubuntu.com/ubuntu noble/main amd64 libgomp1 amd64 14-20240201-3ubuntu1 [147 kB]
Get:17 http://archive.ubuntu.com/ubuntu noble/main amd64 libgfortran5 amd64 14-20240201-3ubuntu1 [930 kB]
Get:18 http://archive.ubuntu.com/ubuntu noble/main amd64 libcc1-0 amd64 14-20240201-3ubuntu1 [47.5 kB]
Get:19 http://archive.ubuntu.com/ubuntu noble/main amd64 libasan8 amd64 14-20240201-3ubuntu1 [3,026 kB]
Get:20 http://archive.ubuntu.com/ubuntu noble/main amd64 libgnutls30 amd64 3.8.3-1ubuntu1 [996 kB]
Get:21 http://archive.ubuntu.com/ubuntu noble/main amd64 bind9-dnsutils amd64 1:9.18.21-0ubuntu1 [155 kB]
Get:22 http://archive.ubuntu.com/ubuntu noble/main amd64 bind9-host amd64 1:9.18.21-0ubuntu1 [50.4 kB]
Get:23 http://archive.ubuntu.com/ubuntu noble/main amd64 bind9-libs amd64 1:9.18.21-0ubuntu1 [1,236 kB]
Get:24 http://archive.ubuntu.com/ubuntu noble/main amd64 libpcap0.8 amd64 1.10.4-4ubuntu3 [151 kB]
Get:25 http://archive.ubuntu.com/ubuntu noble/universe amd64 dnsutils all 1:9.18.21-0ubuntu1 [3,672 B]
Get:26 http://archive.ubuntu.com/ubuntu noble/universe amd64 libneon27 amd64 0.33.0-1 [102 kB]
Get:27 http://archive.ubuntu.com/ubuntu noble/universe amd64 libneon27-gnutls amd64 0.33.0-1 [74.5 kB]
Get:28 http://archive.ubuntu.com/ubuntu noble/universe amd64 geary amd64 44.1-1build1 [2,236 kB]
Fetched 18.2 MB in 4s (4,573 kB/s)
(Reading database ... 1013588 files and directories currently installed.)
Removing linux-image-5.15.0-88-generic (5.15.0-88.98) ...
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-5.15.0-88-generic
/etc/kernel/postrm.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-6.6.0-14-generic
Found initrd image: /boot/initrd.img-6.6.0-14-generic
Found linux image: /boot/vmlinuz-6.5.0-9-generic
Found initrd image: /boot/initrd.img-6.5.0-9-generic
Found memtest86+x64 image: /boot/memtest86+x64.bin
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot
entries.
Found Linux Mint 21.3 Virginia (21.3) on /dev/sda5
Adding boot menu entry for UEFI Firmware Settings ...
/etc/grub.d/proxifiedScripts/linux: 1: version_find_latest: not found
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127
dpkg: error processing package linux-image-5.15.0-88-generic (--remove):
installed linux-image-5.15.0-88-generic package post-removal script subprocess
returned error exit status 1
dpkg: too many errors, stopping
Errors were encountered while processing:
Processing was halted because there were too many errors.
E: Sub-process /usr/bin/dpkg returned an error code (1)
According to this boot - dpkg error after upgrading to Ubuntu 23.10 - Ask Ubuntu
You have used the third party tool “grub customizer” ?
Potential solutions on that Q&A
Since your are testing noble it is probably just better to do a clean install. Wait for a couple of weeks to allow the big transitions currently being undertaken to complete before installing and testing again.
Are you saying wait until 24.04 is released in April?
Yes, I do have grub customizer installed, and I accidentally installed this Budgie beta by accident.
if you are after a very stable 24.04 version, 22.04 LTS users wait until 24.04.1 is released in July/August this year to upgrade
24.04 in April is the first release for mass installation - should be ok but the 3 months is used to catch key issues before the .1 point release.
in a couple of weeks the big transition issues in 24.04 will have occurred - that’s called feature freeze. At that point its bug fixing through to the april release.
