Hi i’ve downloaded brothers drivers to the downloads folder and have tried several approaches to install these but nothing seems to work. Ant suggestions greatly appreciated.
Thanks Newby (Stephen)
Hi @scarbines!
What is the file extension? .deb?
Can you provide the link to the download page?
Thanks for the link to detailed instructions. I keep getting stuck in the early stage where ive downloaded the correct installer file to the Downloads file. I successfully change the directory to downloads. I type in “gunzip-linux-brprinter-installer-2.2.6-0.gz” and I get the response “no such file or directory”. Any thoughts?
Yes I selected the .deb option.
The last set of instructions ive tried to follow are those suggested by fossfreedom listed below.
I always get hungup at the same point I successfully change the directory to downloads. I type in “gunzip-linux-brprinter-installer-2.2.6-0.gz” and I get the response “no such file or directory”. Any thoughts?
Im doing this from the root directory after changing it to Downloads. I must be doing something basic wrong but im so new to this I dont understand what it is. Cheers.
With the command line look closely at what is being typed. gunzip is a command to uncompress the downloaded file linux-brprinter-installer-2.2.6-0.gz
There is a space between the command and the filename
I.e.
gunzip linux-brprinter-installer-2.2.6-0.gz
You are right when I typed my reply to you I got it wrong but it was correct when I ran the code. Cheers Stephen
just to make sure you are in the correct folder type
pwd
what is the result?
Type
ls *.gz
What is the result?
result for pwd = /home/stephen/Downloads
result for ls *.gz = linux-brprinter-installer-2.2.9-0.gz
Look carefully at the results. Your filename is not what you have typed
Should be
gunzip linux-brprinter-installer-2.2.9-0.gz
Hey Fossfreedom thanks for the assistance. The driver has now installed & is working brilliant.
Is there anything I should now do with the terminal window before using exit?
Thanks Stephen
Nicely done!
Just close the terminal, either with exit or pressing the window x button in the titlebar.
