"problème logiciel détecté" is the error message on opening UB 24-04 screen
Hi friends,
after checking the box and listening the audio
I didn’t replied by the system link, thank you in advance for your help !
J.-M.
Salut Jean-Michel!
You mean this?
I only have this kind of message on distributions that I’ve tweaked. Here, a “budgiefied" Ubuntu 24.04.
But I don’t understand this: which box, which audio?
Could you explain a little more?
Salut jlb,
When I’m connecting to the UB system, on UB Orchis theme (paperwall: ocean and rocks)
In the login box :
After I wrote the correct password, the system is working well , but I got this error message
You found it, thank You
Sorry for not being clear…
Napoleon “un petit croquis vaut mieux qu’un long discours”
Thank You Discourse and jlb
Jean-Michel
Envoyé: dimanche 24 août 2025 à 16:15
Je continuerais bien en français, mais bon… :face_with_hand_over_mouth:
Do you regularly keep your system up to date?
Hi jlb,
The system is being kept updated *
as you can see in snapshots
along with the error message.
*automatically (no need for manual intervention).
amicalement,
J.-M.
Envoyé: mardi 26 août 2025 à 11:11
(attachments)
Hi @jeanmi2A!
Okay, but it’s not just snaps.
Personally, I use the terminal: at least you know what’s going on and what might be wrong. That’s what I like about Linux.
Open the terminal (Ctrl Alt t) and copy and paste this line. It’s just an update followed by a little cleanup of unnecessary files:
sudo apt update && sudo apt upgrade && sudo apt autoremove && sudo apt autoclean
I answered you, @Emergency. Hope that helps you.
Many thanks for Your timely answer .
I agree 100%
Linux has the lifeline : both terminal commands and graphical app
and the home cleaning also.
JeanMi2A
Envoyé: mardi 26 août 2025 à 19:26
THANK YOU
Envoyé: mardi 26 août 2025 à 19:40
Thank you, Jean-Michel, but for what exactly? :thinking:
The message is gone, isn’t it ?
Anyway, it’s more annoying than anything else…
The job is made on my system, following your advice 5/12.
JeanMi2A
What a mess !!! Sorry for this
I’ll do that now and hope you will be happy with the answer.
Jean-Michel
Envoyé: mardi 26 août 2025 à 19:31
