Steam Installed but times out when loading on 19.10
Hi all, hoping someone may be able to help me with this, i installed steam Installer via terminal (sudo apt install steam-installer) ran installer ran though script and complete now when i hit to run it shows in bottom bar then times out. i have tried removing it and reinstalling via gui and terminal again with the same results, a quick ddg search would only bring back results about steam not officially supporting 19.10 and problems on 12.10 ect.
If anyone has any suggestions on dependencies i may need ect it would be a great help (I am using all amd products no nivida)
I don’t use steam so cannot directly help here - hopefully someone will.
Other helpful sites will be ubuntuforums.org and askubuntu.com
Upstream may be helpful as well - https://github.com/ValveSoftware/steam-for-linux/issues
found the answer:
  1. Run the following command in terminal:
“/home/$USER/.steam/ubuntu12_32/steam-runtime”
  1. Then launch Steam.
Credit to David Foerster & waqar on ask ubuntu
