Super+E shortcut key is invalid(Budgie 26.04)
Super+E shortcut key is invalid(Budgie 26.04),
The super+E shortcut is valid in bugie24.04 (X11).
give us a hint … what is “Super+E” supposed to-do?
Ok - if this is a default from GNOME, then good spot. We should bridge that.
For the moment you can open your local ~/.config/budgie-desktop/labwc/rc.xml and add
<keybind key="S-e">
	<action name="Execute" command="xdg-open ." />
</keybind>
It is recommended to enable shortcuts by default.
I’ve never used that key combination.
Actually, this applies to Nemo in both 24.04 and 26.04: pressing “Super” + any letter, including
“e,” searches for folders or files in current directory whose names begin with that letter or group of letters.
I added the code to ~/.config/budgie-desktop/labwc/rc.xml but I don’t see what else it’s supposed to do (after restarting, I should note).
I might be wrong, but the problem is simply that Nemo doesn’t (yet) support the desktop in graphical mode—that’s all. :thinking:
Probably the searching capabilities were from nemo-desktop which we are not shipping in 26.04 since its not wayland compatible. Lets see for 26.10
labwc -r would reload the rc.xml change - so the keyboard combination should open the default file-manager.
What I meant to say is that there’s no need to modify ~/.config/budgie-desktop/labwc/rc.xml; Nemo’s search capabilities work without it—as long as it’s running, of course. :confused:
PS: That said—it took me a while to figure it out—“Ctrl+E” is a custom keyboard shortcut, not a standard one.
It is recommended that the Budgie team add a shortcut (Super + e) to open File Manager in Budgie 26.04 for better user experience.
I agree with you, @Tianyazi,but everyone (starting with me) would have tons of keyboard shortcuts to suggest.
Maybe the forum administrators should create a section where we could post our suggestions… or open a contest for the most useful keyboard shortcuts. :grinning_face:
Post on the current development testing thread.
This suggestion unless its a significant bug doesnt fit in the SRU definition for a released version such as 26.04, but we can consider for the development cycle.
