I see these errors in the syslog, issue here or not?
Apr 1 07:57:13 XPS-15 systemd[1730]: Started VTE child process 17972 launched by gnome-terminal-server process 17940.
Apr 1 07:57:36 XPS-15 sudo: pam_ecryptfs: pam_sm_authenticate: /home/janice is already mounted
Apr 1 07:58:26 XPS-15 budgie-wm[2003]: Can’t update stage views actor [:0x5598f6030f70] is on because it needs an allocation.
Apr 1 07:58:26 XPS-15 budgie-wm[2003]: Can’t update stage views actor [:0x5598f60b2340] is on because it needs an allocation.
Apr 1 07:58:26 XPS-15 budgie-wm[2003]: Can’t update stage views actor [:0x5598f60b9b00] is on because it needs an allocation.
Apr 1 07:58:26 XPS-15 budgie-wm[2003]: Can’t update stage views actor [:0x5598f60bb820] is on because it needs an allocation.
